Re: 660 injection pump
Posted by d282 on March 19, 2012 at 10:14:43 from (209.152.94.237):
In Reply to: Re: 660 injection pump posted by Baler dan on March 19, 2012 at 06:12:41:
What did the precup look like? Even with a bad precup it should clear up when warm, unless you have a hole in the piston from a dribbling injector, but then the compression test would show. Did you take the valve cover off to check the valves? Maybe it is simply out of adjustment? Just some thoughts.
