Posted by jal-SD on March 19, 2012 at 14:31:55 from (208.53.222.169):
In Reply to: Re: My H is leaking! posted by kevinj54 on March 19, 2012 at 11:49:36:
It probably has lots of water in the rear end and floated the oil level so it is above the axel seals. C's, H's & M's will get water from leaking or condensation in the rear ends if not used enough to keep the water "boiled" out. To remove the water, leave it set for a day or two so the water settles to the bottom of the housing. Then loosen the big plug at the rear bottom of the housing. After you can turn it with your fingers, take it all the way out of the threads, but keep the plug against the hole, lift the bottom of the plug slightly and let the water drain until the rear end oil starts to flow. If you have never drained it, you will be amazed at the amount of water that will come out. Have at least a 2 to 2 1/2 gallon bucket under the plug to catch your drainings. (Oil will float to the top and can be skimmed off like cream, if you think you want to re-use it.) Also, if it has sat out in the rain, water WILL leak past the indented bolt heads in the platform. I drain my H, which is parked outside, every fall and get a quart or more of water each time. We had an M that we forgot to drain last year. After freeze-up we went to use it, but it wouldn't move. The water froze solid enough that the bull gears wouldn't turn. It took a couple of hours with a Knipco pointed at the underside of the tractor to thaw it. We got more than a gallon of water out of it after it thawed. (My $0.02 woirth. jal-SD)
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
