Posted by Tom Fleming on March 20, 2012 at 02:58:13 from (67.20.233.126):
In Reply to: F30 Front Wheel seal posted by ForeverRed on March 19, 2012 at 13:17:31:
with all due respect, F20 cast wheels will NOT work on an F30. The hubs are different sizes, with the F30 being bigger.
Fordson house and Rice Equipment have bearings and seals, but be prepared for sticker shock. If I remember correctly, there are some older posts with the cross-over numbers for the F30 front bearings.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
