Posted by ForeverRed on March 20, 2012 at 06:22:22 from (209.117.133.38):
In Reply to: F30 Front Wheel seal posted by ForeverRed on March 19, 2012 at 13:17:31:
Thanks for the replies. Just for the record, the bearings from the F30 hubs fit perfectly in the F20 wheel races. They also are the correct distance apart when in the F20 wheel and fit up fine on the F30 spindle. The only issue is just the inner seal which originally appears to be a combination of felt and steel ring with leather and is larger on an F30. I will do as suggested and see if I can find a modern seal that matches ID for the spindle (F30) and OD that matches for the hub (F20). Thanks again guys.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
