Re: 400 Farmall distributor drive lube ?
Posted by teddy52food on March 20, 2012 at 07:46:32 from (209.237.115.153):
In Reply to: 400 Farmall distributor drive lube ? posted by Jon Hagen on March 19, 2012 at 22:30:14:
There should be a grease fitting there or a slotted screw to put one in. Pump a bunch of grease in there , then a stroke at oil change time. There also is one to lube the dist shaft. That one doesn't take much & will come out the back side.
