Re: My H is leaking! More details.
Posted by LA in WI on March 20, 2012 at 08:01:39 from (50.50.81.248):
In Reply to: My H is leaking! posted by LA in WI on March 19, 2012 at 11:14:51:
Leaking H; answers and more details:
CNKS: There was never a stream of leaking, just drip, drip, drip.
ND856:
david G:
CNKS:
kevinj54: "Yes" to you fellows, I did put in 90wt trans oil.
david G:
farmallhal: I pumped 12 shots of grease in the axle zerks, thanks for the idea. Will see if it helps.
CNKS:
S2710:
rustyfarmall: I added it to when it leaked out the plug hole on left side, ahead of the clutch, according to the manual.
Old weldorIT: I tightened the bolts, they were not real tight. Hope it helps.
kevinj54: I added 6 gal, as per the directions in the manual.
jal-SD: My tractor does not sit outside...ever. No water came out last fall when I drained it. Thanks anyway. The old girl worked hard for 50 yrs, now she rests and sometimes plays.
Thanks to all you guys for help. I have a cold Leinenkugel waiting for you.
LA in WI
