Re: H idle to wide open throttle and belly pump issue
Posted by rustyfarmall on March 20, 2012 at 10:46:27 from (216.248.71.224):
In Reply to: H idle to wide open throttle and belly pump issue posted by Farmallb on March 20, 2012 at 09:00:55:
"Cold Blooded" does not mean it is hard to start. Cold blooded means it will sputter, miss, and almost die if you attempt to rev the engine BEFORE it is warmed up.
