Re: Cutout Relay vs. Voltage Regulator
Posted by Bob M on March 20, 2012 at 14:01:58 from (69.207.87.61):
In Reply to: Cutout Relay vs. Voltage Regulator posted by JRSutton on March 20, 2012 at 13:29:54:
Assuming the 3-position light switch is original you Super came from the factory with a voltage regulator. (A cutout-equipped tractor will have a 4-position (L-H-D-B)light switch)
Forget about installing another cutout - it's WAY obsolete technology.
A cutout is the crudest way to control the generator/battery - it depends on knowledge and attention of the operator to manage the battery charge rate. Manage it wrong and you wind up with either a dead or a boiled (chronically overcharged) battery.
A regulator on the other hand automatically anytime the engine is running. Your battery will thank you(!)
