Posted by Ed Hotaling on March 20, 2012 at 15:53:23 from (67.240.55.230):
In Reply to: gas posted by carlton on March 19, 2012 at 22:28:57:
I have an H with a McCormick #31 loader on it and a Ford 850 with a Lord loader. Neither one has power steering. I use them on a little less than 12 acres in Massachusetts. The Ford has live hydraulics and a hydraulic bucket, but the H will load circles around it, depending on what is being loaded. Some folks complain about fuel usage, but I seldom use more than a couple of gallons per day. That's working most of the day making brush piles to burn. As someone already said, the M produces more HP-hrs/gallon. Doing loader work doesn't take a lot of HP, so it will not use a lot of gas per hour. They all get thirsty when you work the snot out of them. The H will lift about a ton, but that's pushing the limit. The Ford won't pick up quite as much. They both steer kind of hard with a really heavy load, but as long as they're moving, they are manageable. It boils down to what you expect out of the machine and what you're used to.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
