AS usual, I agree with my sparky friends Jim and Bob so will just toss in my shortened version.
The Cutout Relay is effectively between the gennys output (ARM post) and the battery. Once the genny is running and charging it closes so the genny can charge the battery. When the tractor is shut down it opens otherwise the battery would discharge via the genny very quickly and the gennys get hot.
If it only has a cutout relay, you need a way to regulate the charge rate so the LHBD switch did that by manually setting it for LOW or HIGH charge.
The more modern Voltage Regulator had an internal cutout relay PLUS it automatically controls the charge rate so the operator doesnt have to choose between low and high charge.
If youre a purist and insist on originality you would use a cutout relay and LHBD light switch iffffff the tractor originaly had it HOWEVER if you want her to automatically charge at a more correct rate you could still use a VR even if it had the cutout originally.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
