Re: Farmall C Hand Bumper
Posted by rhtx55 on March 20, 2012 at 16:53:47 from (207.119.53.151):
In Reply to: Farmall C Hand Bumper posted by Dick L on March 20, 2012 at 15:10:32:
Is the light bar square to the centerline of tractor, that is I would loosen the mounting bolts and twist it to the right a bit & retighten. I agree that shift knob is too high also.
If AFTER removing all the tape & replacing that gearshift knob and it still sits that high, I would either drill out the new knob a 1/2 inch or so, or remove some of the length of the gearshift lever, or maybe even both.
It may need to heated & bent towards the rear enough to provide clearance in the foward position without hitting anything when moved in the rear position.
