Re: 16 cutting disc for my IH#37 Disk.Which ones to buy???
Posted by RPM1941 on March 20, 2012 at 17:36:36 from (173.24.196.59):
In Reply to: 16 cutting disc for my IH#37 Disk.Which ones to buy??? posted by Mike1972chev on March 20, 2012 at 09:27:01:
The CNH discs are without a doubt the best but also most pricey, you have in your favor that as another post mentioned the chance of finding some used, IH/CNH discs were all interchangeable as long as it was the 1-1/8" square arbor bolt. Be warned that getting them tight is a real chore. If possible clean all the contact surfaces that touch such as spools & spacers, you cannot clamp rust & dirt with expectation of getting correct torgue on the arbor bolt, 650 ft lbs is a 200# man on a 6' cheater pipe. I used to set up & deliver these discs when new.
