I'll just throw another fly in the ointment so to speak. The original generators with cut out and high low charge, usually carried a higher field current flow. When you put a voltage regulator on those it will push more current through the voltage regulating points and cause premature failure. As we all well know, the new regulators you get now days are difficult to keep working anyway. Then another thing, it is difficult to actually buy just a cutout now days. Some use a diode in place of the mechanical points, and some use a regulator and only use the cutout portion. For plain and simple, it is hard to beat the high , low charge unless you put in long days of constant running then you will run into over charging.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
