Re: Cub Coil
Posted by Janicholson on March 20, 2012 at 20:46:00 from (67.72.98.47):
In Reply to: Cub Coil posted by Kyrock on March 20, 2012 at 20:35:28:
If designed to operate with no external resistor (either in the form of a resistor ignition wire, or a ballast resistor) they are the same. Often these will say "Made for use with an external resistor".
If it is designed for full 12v operation, it will say "For use without external resistor". Any of these will be the same as well.
A 6 volt coil is equal to the first described, and will work with a 12v system with ballast resistor.
Several pages back there is solid and comprehensive review of this issue. Jim
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
