The big U-shaped notches are hand-holds for lifting the heavy weights on to the tractor. They can also be used to hang the weight on a forklift, then you drive the forklift up to the tractor and slide the weight into place.
The square recesses are for square headed bolts, so one person can tighten the bolts that hold the weights on to the tractor. They are supposed to be facing out away from the wheel hub.
IH designed the system for two sets of weights to be installed. One through the four holes in the center of the weight, and a second using the holes and slots around the outer edge.
If you want to install more than two sets, use all-thread through the four center holes. You make up four all-thread "studs" that are nutted in place on the wheel hub, then slide as many weights on as you want, then add the outer nut.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
