Re: fast hitch disk
Posted by RTR on March 21, 2012 at 09:34:53 from (216.226.179.180):
In Reply to: fast hitch disk posted by Bob M on March 19, 2012 at 07:05:15:
THANK YOU SO MUCH!!
Those findings actually match up because the disk in the 1960 buyers guide came with a 1968 Farmall 140 I've got. The disk from the 1972 buyers guide came with a 1973 Farmall 140 I've got, and the early disk came with a 1956 Farmall 100.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
