Re: Farmall H missing
Posted by Janicholson on March 21, 2012 at 13:39:22 from (199.17.6.207):
In Reply to: Farmall H missing posted by Johninmn on March 21, 2012 at 08:38:24:
I like pete's answer.
Pull and ground one plug at a time till you find which two are missing. Change the missing plugs to a different hole that was working, if the misfire follows the plug that is is. Change plug wires between holes to see if that changes the misfire. A bad cap and rotor can be a contributor to this. Jim
