sflem849 said: I assume you lock your control rod like you would with a 2 way valve. Does this thing give you two way hyd as well?
It's been at least a decade since I've had one on a tractor, so I'm a bit rusty on these. I think the control rod goes to the belly pump contrlol arm, and using it in this fashion does not allow for two-way hydraulic control. You lift and lower an entire cultivator with the center quadrant just like if you were using the stock rod to the pump. If the rear gangs lift seperately from the front, you still hook the hose to the rear port coming out of the belly pump, and it isn't plumbed through this valve. You then still have the opportunity for the delayed lift of the rear section.
I think I've seen one on a SMTA, which would have had live hudraulics. How it was plumbed, I can't recall.
AG
This post was edited by AG in IN at 18:50:36 03/21/12 2 times.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
