Re: Woods L306 belly mower on Farmall A
Posted by farmallhal on March 22, 2012 at 05:35:21 from (76.4.182.217):
In Reply to: Woods L306 belly mower on Farmall A posted by DMartin2 on March 21, 2012 at 21:45:11:
I have a L306 on a Farmall 140 with a hydraulic lift. You just need to obtain the necessary parts to use the L306 on your Farmall A which will be different then those used on a H. The parts are readily available from Woods but are somewhat costly. The Woods decks can be fitted to almost any tractor with the correct parts. My combination of the 140 and L306 works fine as it is used to mow my extended yard which is also one of my hayfields but the 140 will have a few more horses then the A. Hope this helps, Hal.
