Re: Farmall AV left axle rebuild
Posted by gene bender on March 22, 2012 at 13:23:20 from (207.177.56.105):
In Reply to: Farmall AV left axle rebuild posted by ccaissie on March 22, 2012 at 05:29:44:
Final drive need to have 90wt in the bottom pan. Replace the seal on the final and alos the one on the tranny while its apart. You can clean the brake band with solvent or brake cleaner. While ita apart get the clevis on the brake rod free and clean so you can adjust the band when done. You can buy the gasket or make one out of gasket material for the bottom pan.
