Re: Farmall AV left axle rebuild
Posted by Curt Cooke on March 22, 2012 at 13:45:33 from (64.186.50.66):
In Reply to: Farmall AV left axle rebuild posted by ccaissie on March 22, 2012 at 05:29:44:
You will want to replace the seal in the differential carrier, that will be obvious when you take it apart. What you will find is that new seals are less rugged compared to the old ones and you'll find the final drive shaft worn from the original seal. The trick will be to get your new seal to ride on a portion of the diff. shaft that is not grooved.
