Re: MD Sleeve questions
Posted by hatrick on March 22, 2012 at 19:34:33 from (199.48.194.164):
In Reply to: Re: MD Sleeve questions posted by noshi on March 22, 2012 at 18:18:53:
So do I have any other options besides these overbore IH sleeves? It looks like at one time Clevite may have made some. Also I am curious if I can use th 4" pistones I have as they are in great shape and they are very pricey. I can get the appropriates rings for them as I believe there are two sets. Also do you know when pulling these sleeves if I should use a puck/disk? This is what I did on my super C as I had the correct size. My concern is that these sleeves are alot thinner so the shoulder on the lower disk whould have to be very slight. I had talked to someone and they say you could use a flat bar on the bottom of the puller and just span the bottom of the sleeve. It looks like you can but that I would only be able to press them 1/4 in or more and I am not sure if they will pill hard the entire way or not. On the super c once they popped they came out pretty easy. Thanks for your help.
