Posted by Janicholson on March 22, 2012 at 22:10:13 from (12.47.242.135):
In Reply to: Ih cub governor posted by 49bourbon on March 22, 2012 at 19:48:31:
governors keep an engine at a specific RPM, set by the position of the throttle lever. (actully a governor control lever. If the engine is stalling, when the clutch is pushed in, it may be a carb issue (lean operation) causing the stoppage. Try using the choke about 1/4 to 1/2 out and see if it runs. If so it may be a plugged up carb passage. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
