Posted by D Slater on March 23, 2012 at 07:43:03 from (184.15.12.250):
In Reply to: M&W posted by mkirsch on March 23, 2012 at 05:07:44:
Jim already mentioned this but there's a bunch of splined teeth that have to slide a little when clutch is released. If rust or sometimes thick oil gets in there they will stick. Or if its making a noise the bearing that holds pressure on the discs may be bad especially if it wasn't greased regular. Also if not used regularly they will stick, most times using the tractor a bit with handle released and hitting the brakes will break them loose. If the discs are stuck bad it makes it a harder job when getting them apart.
Not bad to remove one from a SM. It can all be done from the outside. After the hand clutch parts are off the bull pinion comes out like a regular SM and a regular bull pinion and related parts can be installed.
This post was edited by D Slater at 07:49:29 03/23/12.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
