M oil presure
Posted by oliverjoe on March 24, 2012 at 09:02:10 from (71.50.47.124):
I just finished rebuilding a Farmall M gas tractor and it runs great but carries almost no oil pressure at an idle When rpm"s are increased it goes up but not as high as it should for a rebuilt engine. When going thru the boxes from the machine shop that did the engine work I found a small brass plug about 3/8 diameter that I never found a home for. There are no visible signs of an oil leak externaly, is there a place internally that this plug should go in. Any help would be appreciated Thank you.
