Re: super m pressure plate fingers
Posted by Janicholson on March 24, 2012 at 14:49:52 from (12.47.242.135):
In Reply to: Re: super m pressure plate fingers posted by bbbuddy on March 24, 2012 at 13:32:54:
They can be replaced if you find them. If they are very good, they are likely in a good plate. They could be welded up and remachined (with fixtures to assure uniformity)and the worn pins replaced.
Unless you have that skill, or determination to use the old one, I would just bite the bullet. Wear can and does happen inopposite directions in the clutch system. as it does it makes a formerly usable part (though worn) impossible to use due to the geometry. Jim
