We did that on an H with a mounted 24 picker on it, out in the corn field, back in the day. Big job, but it can be done. (At least you won't have to remove the picker's elevator before you start.) When you removed the axel bolt on the bull gear & jockey the bull gear around, be careful, the cage that keeps the bearing for the counter shaft on the brake can break easily. You can fish stray parts out of the bottom of the housing through the drain hole with a magnet and I would suggest you get all you can out before you take the bull gear off. Any stray balls & miscellaneous cage parts can cause you a lot of grief when you work on removing the bull gear from the axel. (My $0.02 worth. jal-SD)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
