Re: Need a bigger tractor for hay.
Posted by mkirsch on March 24, 2012 at 15:39:50 from (67.253.161.186):
In Reply to: Need a bigger tractor for hay. posted by Joe Werner on March 24, 2012 at 13:10:19:
The problem you got if you go with something as new as a 656 is the tractor is a LOT more complicated and there's a LOT more to go wrong.
Plus the gassers REALLY like the PREMIUM gas. You really don't want to work them hard on regular unleaded. Mid-grade at least.
300 or 350 is only a few more HP and a few hundred pounds heavier than an H but it will feel a bit bigger. They also add live PTO and live hydraulics.
Frankly I think a 300 or 350 would be just fine if you're on fairly flat ground.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
