Re: 79' International cub 184 smoking out the oil fill ?
Posted by Andrew Psencik on March 25, 2012 at 11:49:59 from (166.205.11.146):
In Reply to: 79' International cub 184 smoking out the oil fill ? posted by Coyote Green on March 23, 2012 at 17:30:06:
This is common. What is happening is called blow by. As an
engine wears, the piston rings wear enough to allow
compression and exhaust to leak by. Thus the pressure fills
the crankcase and exits through the dipstick breather. This
was standard practice until recirculating valves were installed
later. I would not worry too much about it. If it really bothers
you, do a compression test and check against factory specs.
Hope this helps. A.P.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
