First place to check for air leak is filter cover. Lot of those covers don't fit great and also, some 0-rings get cut putting cover on. Have you changed filter because with a milky oil it may have softened up the filter making it even more difficult to draw oil through it so it goes through the bypass screen on end of filter, plugs that , which doesn't take that much. Aerated oil will turn milky looking also even if no moisture in oil. Not likely though. After checking cover, you can add extra oil to cover possible internal air leaks but may not want to waste new oil if it needs a change which it sounds like it must. Three most likely places to suck air, the cover on filter, 0-ring between front and rear sections of transmission and the o-ring on main suction tube in top of filter cavity.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
