Re: cub surging
Posted by sgtbull on March 25, 2012 at 12:57:57 from (163.191.228.254):
In Reply to: cub surging posted by farmallboy15 on March 25, 2012 at 08:37:18:
There is a set screw w/a locking nut on the front of the governor housing. It may still have a factory seal on it (wire w/ lead plug clamped to it.) That is an adjustment that will correct a surge. HOWEVER, there are several other things to ck first. Make sure the rod which traverses the front of the block does not have freeplay. If I recall correctly, there is a woodruff key in that assembly that often causes problems. There are many other areas that can be problematic, as previously mentioned. Your BEST bet, is to get a shop manual that addresses carb and governor adjustment. If you have the tractor, you need the book.
