To the best of my knowledge, and after looking at the parts list there isn't one. The metal of the pedal (excuse the pun like words) Is in contact with the brake pedal cross shaft. To repair it is rebushed locally to the shaft size. If the shaft is worn, the solutions are to turn the shaft down to a just less than the wear, then ream the new fabricated bushing to .0015 to .002" bigger. The other way is to remove the shaft and have it welded back to size and turned/ground to original diameter, then use a bushing to the same spec as above. Be sure to drill for the grease Zerk. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
