Re: 1566 hydraulic issues
Posted by caterpillar guy on March 25, 2012 at 16:11:56 from (24.247.25.227):
In Reply to: 1566 hydraulic issues posted by Andrew Psencik on March 25, 2012 at 09:50:13:
Start by changing the oil and filter. Might even have to change it a second time to get the water out. After that take the cover off under the clutch. With a light look up at the center of the pressure plate if the shaft is not turning or the rivets that hold the hub to the pressure plate are sheared you have just found your problem.
