Re: Clutch Pedal Shaft Bushing.Where to get it????
Posted by sflem849 on March 25, 2012 at 18:36:09 from (69.197.84.39):
In Reply to: Clutch Pedal Shaft Bushing.Where to get it???? posted by Mike1972chev on March 25, 2012 at 15:00:47:
You can buy the shaft from S teiners, OEM, etc as well. IIRC it is a $60 part. My machine shop will buy the shaft when they are busy or make it when they are slow/not ordering other stuff. Think about the time it takes to make it and it is probably a wash. The then bush the pedals to the correct size.
If you want to half do the job you can just buy the new shaft. That should take out half your slop (in theory)
On the side the 1941 H I just bought has about 1/8" movement in the pedal!!! The drawbar also shows only SLIGHT wear. The tractor must have never been used.
