Posted by D Slater on March 25, 2012 at 19:00:21 from (184.15.17.40):
In Reply to: Super MD posted by minnemoblb on March 25, 2012 at 17:49:17:
First? Look for a engine serial number and prefix letters or numbers. Stamped just below head on left front of block. Depending on the time period of engine change different locations may be found of the block casting # and date code. Probably for you the block cast # will be on lower left of block near center of the block. Should find 6 numbers followed by R1 original. Post what you have if different. Date code will be on the left side near rear of Inj. pump or near back behind fuel filter. Original was probably a Y code. Second ? yes problem is in the fuel injection or primary, scavenger pump. # 3 ? Manifolds can be found. # 4 ? Frame rails are the same length on all M tractors, although there is some differences between most gas and diesel ones. Sounds like they may have installed a gasoline upper front bolster on the tractor. Would check chassis serial #. A 54 Super MD chassis is not to common.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
