I have never seen that but I would say the cam lobe is pushing the lifter off to the side while raising it. That would require a different camshaft. The 300 is known for gear coming loose on cam from nut loosening. If it hasn't already damaged block I would say that it will if you just put a new lifter back in it. I saw a cam bearing work it's way forward once and get under a lifter and held valve open. Never know what you find in these engines.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
