I have never seen that but I would say the cam lobe is pushing the lifter off to the side while raising it. That would require a different camshaft. The 300 is known for gear coming loose on cam from nut loosening. If it hasn't already damaged block I would say that it will if you just put a new lifter back in it. I saw a cam bearing work it's way forward once and get under a lifter and held valve open. Never know what you find in these engines.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
