Electricity is somewhat like water, it only flows from points of high Volts to low Volts. The amount of Amps that flow depends on the difference between the high voltage and the low voltage.
When you're starting the engine, your high Volts are the battery (12 Volts) and your low Volts are at the starter (0 Volts). It is very easy to get 200 Amps to flow when your low voltage is 0. The voltage can never go over 12 Volts because the limiting factor is the battery.
When you're charging the battery, your LOW Volts this time are at the battery (12 Volts). In order to get 200 Amps to flow INTO the battery, the charger has to produce a voltage that is much much much higher than 12 Volts.
Use the boost mode to CHARGE the battery, but turn it off before you hit the glow plugs next time.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
