Repeated failure in the same position? I don't think the camshaft moving around is the the problem, since it doesn't affect any of the other lifters. Unless there is something wrong with the lobe, which you said there isn't. This does seem like an excessive bore clearance problem. Drop a good lifter in the bore and reach up through the bottom and see if the lifter moves laterally while resting on the camshaft. Or, if you have the stuff, mic the bore. To fix it, I think I would have a machinist make a lifter without any holes in the bottom half, perhaps also a little oversize if the bore is worn.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
