Re: Farmall A Magneto
Posted by Haas on March 26, 2012 at 06:22:29 from (75.246.120.122):
In Reply to: Farmall A Magneto posted by Phil Eastman on March 25, 2012 at 19:43:46:
If you have the original manual, it will tell you how to service the points and how to time the magneto. Make sure you have all the parts in there going by the pictures in the manual. If the magneto impulse trips (makes a clicking noise when you turn the engine with the crank) and it makes a spark and the engine has compression, then the tractor should start and run. Make sure you have good gas and the carburetor is not plugged up. Change the oil in the air cleaner and make sure there are not any mud wasps nests in there.
