Re: Belt for Delco 10SI alternator installed on Super M
Posted by Dean Olson on March 26, 2012 at 09:09:09 from (166.205.140.102):
In Reply to: Belt for Delco 10SI alternator installed on Super M posted by mkirsch on March 26, 2012 at 08:23:51:
The technique I use is to cut an old v-belt and wrap it around
the pulleys and measure. Take that measurement to parts
house and they'll fix you up.
