Re: Belt for Delco 10SI alternator installed on Super M
Posted by rustyfarmall on March 26, 2012 at 09:16:26 from (216.248.71.224):
In Reply to: Belt for Delco 10SI alternator installed on Super M posted by mkirsch on March 26, 2012 at 08:23:51:
If the alternator is mounted using the original generator bracket, you can use the original generator belt. IH part number 49341D. That is what my M uses.
If someone mounted the alternator using one of those "universal" alternator mounting brackets, such as mine is, you will need to modify the bracket slightly so the alternator sets on TOP of the bracket. A couple of square nuts and a welder will do it.
