Pulling the engine is easier! You take the oil pan off, and the cross arm to the steering. You have to take the air cleaner assembly cast piece off, and the clutch housing top off. Then you take apart the drive shaft, pull that out and take out the pressure plate, clutch and flywheel, and it is heavy! Now you can get to the rear main seal. If your back bearing is worn which I bet you money a new rear main seal will not stop the leak, and you will be upset with all the time you wasted trying to fix it. Been there and done that. If you don't believe me ask sflem. He knows too!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
