Posted by janicholson on March 26, 2012 at 14:22:28 from (199.17.6.10):
In Reply to: H makes oil posted by farmallJeff on March 26, 2012 at 14:12:50:
Yes. The seal on the pump is leaking into the engine. Pretty easy fix. Two seals are used (depending on pump type) one is plane lip seal, the other is an O ring. If the shaft is grooved, the seal should be placed to not run in the groove. If Oring the use of a speedy sleeve and minor machining of groove in housing is needed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
