Re: removing the cast center, need help
Posted by kennell on March 26, 2012 at 15:47:23 from (142.68.111.75):
In Reply to: removing the cast center, need help posted by BigTone on March 26, 2012 at 15:42:44:
No tricks to it. Just remove the two inner and two outer bolts that hold the wedge onto the axle, then your ready to take the hub off the axle. Keep in mind after sixty plus years the bolts might need heat to get them to turn. Good luck. Kent
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
