Re: Leroy - I need rake help!
Posted by Jim Becker on March 26, 2012 at 16:56:47 from (71.252.156.130):
In Reply to: Leroy - I need rake help! posted by JRSutton on March 26, 2012 at 10:26:27:
I'm thinking that the eccentric should effectively be the bearing for the reel shaft. The stepped down part of the eccentric (where the welding was done) should be the part that rides in the u-shaped bracket. Seems like there should be enough washers/spacers or something to use up any open space on the reel shaft so the u-shaped bracket can't fall into a gap between the sprocket and the eccentric. You mention (but I don't see in the pictures) a large washer. Additional washers between it and the sprocket or on the other side of the eccentric should close any gap between the eccentric and the large washer. This should keep the reel shaft from running directly on the u-shaped bracket.
