Re: removing the cast center, need help
Posted by Mike1972chev on March 26, 2012 at 16:59:30 from (99.50.229.71):
In Reply to: removing the cast center, need help posted by BigTone on March 26, 2012 at 15:42:44:
Yes,Like Kennell said,
I would start with P B Blaster on the bolt threads.4 per axle wedge.2 inside,2 outside.
If they do not come easily,it might take some torch work.
SAME with the outer ring against the rims.
Be sure and clean the bolt threads up well and the threads in the wedges before re assembly. Torque all 4 bolts evenly when retightening!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
