Re: Belt for Delco 10SI alternator installed on Super M
Posted by charlieu on March 26, 2012 at 17:06:54 from (209.131.230.214):
In Reply to: Re: Belt for Delco 10SI alternator installed on Super M posted by mkirsch on March 26, 2012 at 10:53:53:
third party image
third party image
Here are a few pictures of an alternator mounting bracket that I have designed. The bracket has slotted holes where it bolts to the cylinder head making it easy to get the belt correctly aligned with the waterpump pulley. This setup is designed to use a Delco 10SI alternator with the orginal generator belt. The picture of just the mounting brackets is shown on a International 300 but the M, SM, 400, 450 bracket is similar.
My e-mail is open if you are interested in purchasing a set of mounting brackets for $40 or I can also do a complete kit.
