Re: Re: Re: Farmall H runs a while then quits
Posted by The Red on September 18, 2000 at 04:18:32 from (12.75.196.103):
In Reply to: Re: Re: Farmall H runs a while then quits posted by Paul on September 17, 2000 at 20:02:46:
Paul I recommend you drain the tank and remove the strainer assembly. I think your inlet pipe on the strainer might be partially plugged. I went through this problem with my JD 4400 combine. A rusty gas tank was the culprit in my case and the rust was plugging up the inlet pipe on the strainer.
Post A Followup
: Re: Re: Re: Re: Farmall H runs a while then quits
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
