Re: SMTA's Propane tank
Posted by Centex Farmall on March 26, 2012 at 19:21:14 from (166.147.69.249):
In Reply to: SMTA's Propane tank posted by redgems on March 25, 2012 at 20:35:29:
Here are some tank photos for what you are looking for. I have two of these West Texas tractors. Their tags are 61 numbers apart. One has the ES suffix and the other is a DS. The tanks are made by Wendland Mfg. in San Angelo, Texas. The tanks are dated 1954.
I've seen another MTA like these at the Temple tractor show. It was very much unrestored and in work clothes.
third party image
Left side view showing valves. The rear hood mounts are welded to the front of the tank.
third party image
This view shows the tube for the steering and throttle.
third party image
This shows the 10 o'clock location of the valves and the fuel gauge at 2 o'clock.
third party image
third party image
This is the other tractor, showing a closeup of the valve assembly.
